Author Topic: Waxoyl  (Read 2600 times)
Offline Gambit
Waxoyl
« on: 03 December 2003, 16:34 »
whats the crack with it?
it prevents rust i know, but is it only for undersides or wha
Offline Hammy
Re:Waxoyl
« Reply #1 on: 03 December 2003, 21:54 »
Normally used to spray inside wings,sills and areas that either collect water or moisture.  Best applied when its dry and the inner wings etc are too...
Either comes in a spray can format or paint pot.   Better in my opinion is the spray can as you can fit a long tube and spray it right into the corners..
Hope this helps a little.
Blue MK2
Re:Waxoyl
« Reply #2 on: 03 December 2003, 23:52 »
Is that the stuff that looks like vastaline? :-\
If so oopps!
Offline modulater
Re:Waxoyl
« Reply #3 on: 04 December 2003, 21:10 »
Its good stuff and you probably all get a similar thing coming out of your boots onto the back panel in the summer.
Yeah i'd agree with the long plastic pipe that has lots of holes in it and you thread it into the box sections and spray it, My brother uses it on his old MGB and it works a treat.
Blue MK2
Re:Waxoyl
« Reply #4 on: 04 December 2003, 22:49 »
yaeh i had that in my engine all over the place but i cleaned it off. will it rust quick?  :'(
Yeah its soo annoying on the rear of the car!
turbo
Re:Waxoyl
« Reply #5 on: 06 December 2003, 23:33 »
you normaly put that stuff on the inside of the doors and boot stops the rust!.
Blue MK2
Re:Waxoyl
« Reply #6 on: 07 December 2003, 01:07 »
ohh shiiiiii
i took it all off my engine bay, inside doors and boot!
how much is this stuff? what do you get with it?
