Author Topic: Bubbling Roof nr. Sunroof  (Read 2975 times)
Offline dan
« on: 02 December 2003, 21:50 »
Hi,
Managed to hunt down a Campagin, however its a tad rusty round the sunroof. Bubbling up is also on the side of the roof when you wind the sunroof back.
Has anyone ever restored a Mk1 with this kind of rusting?
I could post pictures if need be.
Offline AdamB
  • The Perfect Storm
Re:Bubbling Roof nr. Sunroof
« Reply #1 on: 02 December 2003, 21:54 »
No roof - no rust ;)
I hear the sunroof is a bit of a water trap, so there should be plenty of help out there for you. If the price reflects it, then buy it - reckon it cant be too much of a job to repair
I don't own this anymore - I just can't be arsed to change the picture
Offline alexh
« Reply #2 on: 02 December 2003, 22:06 »
the only way to get rid of rust on any panel is to cut it out and replace with new metal, a good bodyshop will be able to do this . don't go down the line of  rust eaters etc if the rust is any worse than surface as it will just bubble up again
Offline Justins145bhpMK1
« Reply #3 on: 03 December 2003, 12:00 »
Mine had exactly the same prob when I got it and actually had holes in it, its probably caused by bloked drain hoses so rainwater sloshes about in the roof.
I didnt have mine welded, just proffesionally rust treated and resprayed, got the drain tubes sorted and its been ok ever since.
