Author Topic: Fitting single lights onto quad golf  (Read 1987 times)
Offline Jowe-ziff
« on: 29 April 2006, 17:42 »
i have a 1.6 '92 driver and was wondering how to fit single lights because i prefer the look but the inner lights are full beam if im not mistaken and the outer ones are just normal lights
how to do i make it all work in one light?
Offline fugazi33
Re: Fitting single lights onto quad golf
« Reply #1 on: 29 April 2006, 18:17 »
Hi there,
the outer lights have dipped and full beam, so you disconnect the wiring to the inner spots, take the grill out and swap in a single light grill, job done, hope this helps.
Offline Uruk Hai
« Reply #2 on: 29 April 2006, 22:08 »
As said above you just unplug the spotlights and thats it but be aware that you do lose a lot of light when on full beem but if most of your driving is on well lit roads it doesnt really matter
Offline Jowe-ziff
« Reply #3 on: 01 May 2006, 17:03 »
so basically i jus forget about what the inner lights do and jus wire up the outer ones?
im planning on outting big bumpers on as i only have a driver could i put some bright lights ionto the bumper for when i do actually need them then?
thanks
Offline Uruk Hai
« Reply #4 on: 01 May 2006, 19:20 »
Yes you could put lights in the bumper, you may be able to get a set of bumpers that allready have fog lights in the front but then you'll have to wire those up
Offline Steve_B
« Reply #5 on: 04 May 2006, 15:44 »
If you're worried about loss of light the the way to go is an uprated headlight loom and bulbs with a higher power rating.
Veedubgt18v
« Reply #6 on: 04 May 2006, 16:00 »
and the fog lights arent actually that great compared to the inner spots
