Author Topic: Welded fron big bumper nuts!  (Read 3094 times)
Re: Welded fron big bumper nuts!
« Reply #20 on: 28 April 2006, 21:08 »
there may be a little fuel pressure in the lines, remove the fuel pump relay and turn the engine over, that should suck most of it out then leave it for a few hours before you crack the lines off.  Have a rag round the pipe when you undo it to catch any spray, should cover it :)
Offline golfmk2boy
« Reply #21 on: 29 April 2006, 12:38 »
Managed to remove the bolts this morning after coating them with wd40 last night.
Front end is completely removed now.  Just need to disconnect driveshafts and exhausts and I should be near to removal of the engine.
IS there anything else i will have to look out for or do to remove the engine... I know that I will have to disconnect gearbox from mounting aswell.... but I do not know whether I will need to disconnect driveshafts from gearbox.
Any suggestions? :smiley:
« Reply #22 on: 29 April 2006, 16:04 »
Disconnect hte shafts from the gearbox & leave them in, assuming you're using the same gearbox, or another one the same.  No reason to take the shafts out unless youre putting in a different gearbox or need to do any of the CV boots.
Offline golfmk2boy
« Reply #23 on: 29 April 2006, 16:15 »
I will be swapping the gearbox over to the other engine.
So should I just disconnect the shaft from the gearbox?  :undecided:
« Reply #24 on: 29 April 2006, 17:23 »
yeah remove the gearbox ends of the shafts, you'll need a spline head tool though.
Offline golfmk2boy
« Reply #25 on: 29 April 2006, 18:23 »
Hi,
Sorry.... should I remove the driveshaft connection onto gearbox, or remove the driveshaft wheel connection.
Sorry for sounding like such a plonk  :undecided:
« Reply #26 on: 29 April 2006, 18:29 »
driveshaft -> gearbox connection
leave the shafts attached to the wheels :)
