Author Topic: Power Steering  (Read 658 times)
Offline Jowe-ziff
Power Steering
« on: 27 April 2006, 09:33 »
is it possible to put power steering on my 1992 1.6 driver?
if so how much and is it a pain in the arse to do??
thanks  :nerd:
Re: Power Steering
« Reply #1 on: 27 April 2006, 10:03 »
it is possible, you just need to get a kit and fit it on really, just make sure you get EVERYTHING including the steering column universal joint & boot, rack mounting bush, brackets, reservoir, pulleys etc.
Any MK2 kit from a 1.6 upwards will fit as well, all the brackets are the same and the mounting s are present on the block.
Ideally its an engine out job, but apparently its doable by dropping the subframe a bit, though you risk shering off the mountings which is an even bigger job than an engine removal!
