Author Topic: Gear selection alignment... mk2  (Read 5408 times)
Offline Davs mk2 16v
« on: 02 December 2003, 14:46 »
i've got a mk2 16v, and yesterday my gear selection messed up. The front engine mount is on its way out and ive been driving it for 4 days with it like it is.
but now i can't get it into first gear properly. I have to push down the gearknob and head into reverse but not actually put it in reverse. if you know what im saying.
whats the best way 2 sort it???
Offline Leejaydoob
Re:Gear selection alignment... mk2
« Reply #1 on: 02 December 2003, 15:20 »
renew engine mount and check for wear in gear selecters
« Reply #2 on: 02 December 2003, 16:35 »
i'm changing the mount in the morning at my mates VW garage/breakers. Should i replace it with a standard 16v mount or can i use a VR6 one??
the linkage seems to be fine, it just sort of happened all of a sudden, so i can't see it being wear. Might just change it all anyway....  :(
Blue MK2
« Reply #3 on: 02 December 2003, 17:10 »
Do you get a rattle noise when you go over a bump due to a worn engine mount?
Nice car by the way Dave. Think I saw it on DemonVW?
What size/ rims are they?
« Last Edit: 02 December 2003, 17:10 by Blue MK2 »
« Reply #4 on: 02 December 2003, 17:45 »
thanx  ;D yeah, it is my car on demonvw m8.
the wheels are 17" BK racing. bit of a bugger to clean, especially now ive got discs all round, but they're worth it i suppose.
well, the exhaust keeps bangin on the rear axle and started blowing 2 days after i sorted it. I gotta get it on the ramp to line up the joints properly.
Has anyone got a VR6 front engine mount on their car?? i figure it would take the strain of me caining it better  ;)
Offline Gambit
« Reply #5 on: 02 December 2003, 17:46 »
just use the late 16v Hydro mount, not the rubber bonded one
Blue MK2
« Reply #6 on: 02 December 2003, 17:55 »
what about G60 ones?
Offline Gambit
« Reply #7 on: 02 December 2003, 18:06 »
wont fit
G60 & late 16v share the same rear hydro mount
different fronts though
vwspares.co.uk are cheap for front hydro mounts
Offline Jon16
« Reply #8 on: 02 December 2003, 21:30 »
My 1990 16v is difficult to put into 2nd gear without crunching particularly when cold. I think it has a quick shift kit on it and always assumed this is a worn syncromesh (its does about 138k). Is that the likely problem or could it be a gear linkage alignment problem? No other probs with it. Any thoughts? Thanks  ;D
action al
« Reply #9 on: 03 December 2003, 00:01 »
I used to have to do that with 1st on my 16V until I replaced the gear linkage bushes. It was the one nearest the engine that was causing the problem, if thats any help?
