Author Topic: auto down and up on windows  (Read 3592 times)
Re: auto down and up on windows
« Reply #20 on: 26 October 2006, 13:56 »
if the window goes up & stops, goes up & stops etc, its because the motor thinks something is blocking the window and is stopping it.  lube up all the channels with proper silicone lube, can get it from halfords.
If it doen't work at all and the reset method don't help, have a look in the rubber bellows between the door & body, check for broken wires.  Factory MK3 windows shopuld have auto up & down, the Corrado loom i fitted to my MK2 Does :cool:
P.S. check if your kit is a proper factory system, and not after-market, this may be the difference!
P.P.S. Woo I have a medal  :grin:
Offline DanT
« Reply #21 on: 30 October 2006, 11:54 »
Ours is the same as yours, 1 touch down but not up. I hunted through manuals etc and from memory I am sure it was an option to go back up.  I can't guarantee this but I am as sure as 10 sure things that I read that in the handbook somewhere.
Dan T
95 MKIII gti 8v.
97 T4 syncro caravelle.
Offline chrutchy
« Reply #22 on: 30 October 2006, 19:30 »
ive just changed my drivers side motor as mine went wrong
and the one i took off had auto up and down and
the one i put on was from an older model and it has auto down bu not auto up
Offline whit
« Reply #23 on: 11 December 2006, 15:06 »
i've had this problem for years now.......still looking for a solution
passenger side works fine but drivers side goes down fully using the auto feature but not fuly up. it goes up either part way then baqck down abit or right up then partly back down.
have tried the resetting relay suggestion but hasn't worked for me.
i'm considering buying a new switch but don't want to waste my money so is it likely/unlikely to be the switch???
« Reply #24 on: 11 December 2006, 15:34 »
sounds like the safty is cutting in, try lubing up the runners
Offline whit
« Reply #25 on: 11 December 2006, 16:00 »
do you have to remove the door trim to do this or can you do it without too much messing around by 'squirting' stuff between window and rubber?
« Reply #26 on: 11 December 2006, 16:09 »
i think if you wind the window right down and spray some silcone lube down the channels this should do the job.  Halfords sell the stuff in a spray tin and it works well :)
Offline kt_gti
« Reply #27 on: 12 December 2006, 11:42 »
My L reg Golf gti on the drivers side the window goes up and down on one touch but the passenger side only goes down on one touch. But when i open it if i unlock it and then turn the key back the otherway fully all the windows go down. I thought this was quite weird  :huh:
« Reply #28 on: 12 December 2006, 12:05 »
I think thats a safetly feature, my corrado 1 touch windows are the same.  The windows all open/shut on the key due to the cool total closure system, it should also work on the sunroof I think?  8)
