Author Topic: New brakes on the way... should i go braided hoses aswell?  (Read 2103 times)
Offline simonmk2gti
So, got some drilled and groved disks being fitted on friday, with mk3 callipers on the rear... should i spend the extra and go for braided hoses? what sort of difference will it make??
im really looking forward to it, as at the mo, my brakes are not that good... :(
SO, is it worth spending the £60 odd on braided hoses?
Offline Mr Blue
Re: New brakes on the way... should i go braided hoses aswell?
« Reply #1 on: 23 April 2006, 14:51 »
duno about hoses but change those hand break cables  :wink:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 23 April 2006, 17:59 »
Braided hoses will give you a firmer pedal, with less travel, Why... because they dont expand when you hit the brakes, like the braided rubber hoses do..
do all the flexis though! as otherwise its a waste of time and money, and change to synthetic brake fluid too!
Tom
« Last Edit: 23 April 2006, 18:16 by thom89 »
Offline dubslug
« Reply #3 on: 23 April 2006, 18:11 »
yeah if u r gonna do it make sure u do them all, or it puts extra pressure on the ones u hvaent changed
1992 pearl grey 8v
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 23 April 2006, 23:41 »
The kits only come in 4 or 6 line packs unless you buy direct from goodridge. You need the 6 line option as you have discs on the back. you will need to replace the handbrake cables to run mk3 rear calipers as said before.
I would defiently reconmend it's something you look at at this point in the car's life. saves having to remove and bleed again if you fit them now :)
Mk4 Golf 150PD
Offline ...joe
« Reply #5 on: 24 April 2006, 09:15 »
you might as well, the only thing is if the originals are all rusted up they might be a proper pain in the ass to get off which could mean more money spent on labour.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline AudiA8Quattro
« Reply #6 on: 25 April 2006, 12:19 »
I would leave the hoses standard, as they don't really make that much difference.
Veedubgt18v
« Reply #7 on: 25 April 2006, 15:32 »
ok.......made a big difference on my car.....
at the very least based on the above^^^ comment u can just fit and forget they wont split or anything come mot time
« Reply #8 on: 25 April 2006, 17:46 »
They will only make a big difference if the ones on the car are knackered.
If you are going to change them anyway then its worth putting braided on, if the ones on the car are ok then leave well alone.
Offline Dizzie
« Reply #9 on: 25 April 2006, 22:26 »
if the metal part that attaches to the hose looks rusty as spray on some 'rost off ice' which will ease removal!
Mk4 Golf 150PD
