Author Topic: oil pressure gauges??  (Read 1639 times)
Offline silkyballs
  • more tea vicker??
« on: 22 April 2006, 02:37 »
for some reason since my rebuild my oil pressure light doesnt seem to work.so im thinking about installing a very small gauge sumik nice and tidy and doesnt look out of place down in the centre console a thought that way i havent got to worry about the light not working.
but where do i start to look for one any thoughts would be sweet :grin:
http://[img]
Offline ...joe
Re: oil pressure gauges??
« Reply #1 on: 22 April 2006, 10:29 »
get a vdo gauge as they look (because they are) OEM and can be found on audi's mostly. they are 52mm and is a common size. pretty easy job too!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 23 April 2006, 23:32 »
are you sure the sensor is plugged in? If we're talking a mk2 8v engine it's the front one on the top of the oil cooler. :)
Offline silkyballs
  • more tea vicker??
« Reply #3 on: 23 April 2006, 23:49 »
yep defo everything is plugged where it should be im toying with the idea of one of those three way digi gauges???it does oil pressure,oil temp and water temp but i'd prfer amp/volt metre instead.ive had the clocks out and they seem fine checked all connections and earthed the wires going to the switch so must be a nightmare inbetween???lol
http://[img]
