Author Topic: bending door back  (Read 1092 times)
Offline golfmk2boy
bending door back
« on: 21 April 2006, 17:36 »
Hi,
A thief with a crowbar  :angry: hurt my golf tuther week.
Not sure what he was after cos there is nowt in there, so he must have wanted to mod my door a little and reshap the beatuiful lines of the driver-side.
Consquently my door sits downwards now.  I tried pushing it upwards to bend it back but this doesnt seem to work.
 :angry: :angry: :angry: :angry: :angry:
Its so easy for them!... I spend hours, and then the f**k*rs do what they like in 5 minutes
Offline jezza16v
Re: bending door back
« Reply #1 on: 21 April 2006, 19:30 »
Bad luck  :sad:  Explain in more detail in which way and where it has been bent, I presume the door is down at the latch end? When you shut the door does it straighten up a bit as it catches on the latch. Is the door unit actually bent?  :smiley:
Offline Haribo!
« Reply #2 on: 21 April 2006, 20:20 »
Not sure what he was after cos there is nowt in there, so he must have wanted to mod my door a little and reshap the beatuiful lines of the driver-side.Its so easy for them!... I spend hours, and then the f**k*rs do what they like in 5 minutes
What is it with wayne kerrRRS like that!!!! sorry im not helping at all but for fcuk sake!!!!
Offline Mr Blue
« Reply #3 on: 22 April 2006, 00:19 »
if your door drops then stick a piece of wood between the door and the bottom hinge. now firmly close the door and this should raise it :smiley:
Offline golfmk2boy
« Reply #4 on: 22 April 2006, 23:46 »
Its bent..... it still closes however water can get through now.
It slopes downwards near the handle side, also my door handle is f**ked.
I need a new one if anyone has one spare??
« Reply #5 on: 23 April 2006, 11:20 »
try loosening the door catch pin in the door jamb and moving it up a bit, if its only dropped down but not bent outwards this should fix it I think.
