Author Topic: beware of VW 'specialists' !!!  (Read 1232 times)
mr_angry
« on: 20 April 2006, 19:55 »
Golf GTi '88 8v pb digifant 85k miles
Hi,
Just thought I'd post regarding so called vw 'specialists'. Cam belt was changed on my gti, a month prior to me buying it, at one of these specialists. When test driving car, I thought it was a little flat, but nothing that couldn't cheaply be sorted, so I set too changing dizzy cap, rotor, timing, temp sensor, checking for vac leaks etc, etc, but car still performed poorly with very bad mpg, and lots of misfire. Having read endless topics on here, thought i'd check valve timing - low and behold - punched mark on cam pulley was two teeth away from lining up with cylinder head - now I know it's easily done, but come on - bloody specialists!
Lined everything back up today, re-timmed, and car runs fantastic! So in future, I'd be more inclined to trust myself and the posts from people who know what they're talking about on this forum than the so called 'specialists' out there.
There's a cracking link somewhere on this forum that details how to set up your valve and dizzy timimg with pictures, but im buggered if I can find it again - think it linked to a USA site.  Anyone unsure how to do it, let me know and i'll sort out a step by step.
Offline Diluxe
Re: beware of VW 'specialists' !!!
« Reply #1 on: 20 April 2006, 21:24 »
Hey,
i think quite a few peeps (including me) on here would be grateful for a step by step guide.
look forward to see it  :grin:
1997 16V
« Reply #2 on: 20 April 2006, 23:28 »
All the info you need:
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
If you have a K-Jet motors its more simple, the idle/co is just set it at idle with the lights on, no need to rev the engine or owt.  Plus ihe ignition timing is set at idle rather than at 2k rpm.
mr_angry
« Reply #3 on: 21 April 2006, 01:54 »
Here Goes - Asuming like me, your pretty much a novice - here's what I did. Firstly, read rubjohnny's excellent link above, then read it again and inwardly digest.
1. Make a note of where your plug leads connect. Looking at your engine from the front, cylinders are numbered 1,2,3 and 4 from left to right. On the distibutor, the connection nearest the engine block is to cylinder No.1 then going clockwise, you got No.3, No.4 and No.2. If you don't know this, do what I did and draw a piccy! Remove your dizzy cap, disconnect leads from spark plugs, and remove your plugs (makes it easy to move car in step 2 )
2. Put car in 5th gear, and pull the car slowly forward until the piston in No.1 cylinder is exactly at the top of its stroke - you can insert something like a thin piece of dowel into No. 1 cylinder to feel when the piston is exactly at the top.
3. Remove your rocker cover, and top section of cambelt cover - haynes manual useful here to locate all the nuts and bolts you need to undo. Now look at the cam pulley - there should be a mark scored or punched on the inside face. This should be exacly lined up with the top of the cylinder head. Mine wasn't - it was about two pulley teeth away. If it doesnt line up, you need to slacken off the cambelt tensioner and move the cam pulley so the mark lines up. Get a feel for the tension on the belt first so you know the tension you need when you tighten it back up - sure I've read on here that you should just be able to twist it through 180 degrees using finger and thumb pressure. Now the mark lines up, tighten up the cam belt tensioner adjusting for the correct tension.
4. At this point, think sh*t, I'm way outa my depth here, the damn thing's never gonna start again!
5. Look at the rotor arm on the distributor - it should be pointing to the No.1 position towards the engine block. There's a small nothch on the distributor body that marks No.1. Mine was so I'd no need to undo slacken the cam belt and adjust the intermediate shaft. Replace cam belt, and rocker covers, and refit the distributor cap and plug leads in the correct order, hoping that as in my case, you four year old daughter hasn't nicked the nice piccy you drew of where everything goes, and scribbled all over it.
6. That's the valve timing sorted -  next I meticulously followed rubjonny's post to get the dizzy timing spot on.
7. Sit in awe and wonder when your car starts and grin at just how much better it sounds, and how cleanly it revs, and how instant the response when you open the throttle! Go for a self congradulatory beer, and feel justifiably smug!
There's probably something I've missed, or got wrong, but it worked for me and the difference is quite astonishing. Hope it's of use to someone.
Mr_slightly_less_angry.
« Reply #4 on: 21 April 2006, 20:00 »
only a couple of things to add:
1. Don't assume sparky lead #1 on the dizzy will be closest to the head, someone could have fiddled with the dizzy and thrown it all out. Once you have piston #1 at TDC & the cam lined up check where the rotor arm is pointing.
2. Piston #1 has 2 TDC points, the compression & exhaust stroke.  So when the piston is at TDC check where the cam mark is, if its nowhere near turn the engine over again :)
3. No need to roll the car to turn the engine over, you can just use a spanner on the crank sproket bolt, take all the spark plugs out first though or you'll be fighting against the compression in the cylinders and it'll be very stiff!
