Author Topic: Fuel Pump Relay Help  (Read 1435 times)
Offline dan.lewis
« on: 19 April 2006, 16:58 »
Bought a 85 mk1 Cab and whoever had it has the fuel pump on a switch. So to start the car switch has to be on and when engine is off switch has to be turned off.
I'd like to get it running of the relay again,
So diagrams/doodles anything that helps me out
cheers
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
Re: Fuel Pump Relay Help
« Reply #1 on: 19 April 2006, 19:40 »
Is it not maybe a good anti-thft device having it on a switch?
 :smiley: :wink: :undecided:
Offline RYoungMK1GTI
  • Mk1 Golfs R still the Best
« Reply #2 on: 20 April 2006, 19:35 »
i have the the same problem after the usless cu*ts and spud sport fu*ked it up ill let you know when i figure it out
Offline richandhazel
« Reply #3 on: 29 April 2006, 00:28 »
Never permenantly bypass the relay (we've all done it temporarily to prove faults)...........you don't want the car pumping out fuel after an accident where a fuel line has been ruptured. For what it costs, just not worth the risk.
I have some diagrams that may help depending on how badly your loom has been doctored.
