Author Topic: abs warning light / stall,cut out  (Read 1136 times)
Offline geo3
« on: 18 April 2006, 16:18 »
my abs warning light  stays on all the time? clocks have got a mind of there own.
they work ok then they will go off, then they will stick with no readings
just recently its started to stall/cut out at low revs. untill its warmed up no problem starting but its a worry,as no engine power = no steeering
read something about " hall sensor" is this something to do with it ?
any one else had anything similar happen ?
any ideas?
Offline monkeyalan
Re: abs warning light / stall,cut out
« Reply #1 on: 18 April 2006, 17:00 »
the abs light is probably one or more sensors knackered
stalling could be one of a few things. relays,dirty throttle body , faulty coil pack....
Offline Obvious
« Reply #2 on: 18 April 2006, 18:31 »
Just had a problem with my ABS, turned out to be the offside front sensor.. Bulb had blown too so had a new bulb wired in as a new unit is £70   :sick: Not had any of the stalling/cutting out problems  *touch wood*
