Author Topic: MOT due and would you believe.. I just get an ABS problem  (Read 1638 times)
Offline Obvious
Ok I have the MOT for the car due tomorrow, and this Friday  driving down to the in-laws the abs warning lamp comes on and stays on(sods law right!). Not a problem I think to myself as it more than likely will be a sensor at fault after reading up on these problems on here. So for a day or two it's been on and won't come off....Anyway, yesterday I start the car up and the ABS warning lamp is not coming on at all, so now i'm getting a lil worried.. Phoned garage up I use on the Saturday and they said they will read the codes and try sort it before it goes in for it's MOT... I just wondering from anyone who's had problems with the ABS has any idea what's at fault here.. Sensor? Pump? Bulb? Relay?.. Brakes appear to be fine in working order, not had a chance to test the ABS proper yet, but hasn't been locking up stopping at speed yet.. Any directions to look at would be appreciated.
Offline JAY1
Re: MOT due and would you believe.. I just get an ABS problem
« Reply #1 on: 17 April 2006, 17:44 »
could be anything! i had a problm and it turned out to be low battery voltage!
Offline AudiA8Quattro
« Reply #2 on: 18 April 2006, 18:10 »
More likely will be a sensor, o/s front seems to be the favourite.
Offline Obvious
« Reply #3 on: 18 April 2006, 18:28 »
Well GolfVR6 your guess was indeed correct  :laugh: It was the Offside front which had gone, also the bulb from the unit had blown too hence the reason it was not illuminating. So garage has rewired in a new bulb instead of replacing the whole unit as he doesn't justify the £70 it would have cost to replace the whole unit. Good news is, it sailed through it's MOT  :grin: So pump isn't on the way out and bonus... no fault codes found either *breathes a sigh of relief*
« Last Edit: 18 April 2006, 22:41 by Obvious »
« Reply #4 on: 18 April 2006, 18:35 »
Good guess indeed, i've replace 2 o/s/front sensors on mk3's this year already  :smug:
Offline Obvious
« Reply #5 on: 18 April 2006, 18:37 »
2!! well here's hoping this one lasts a little while... Now it's off to try and sort out the other little annoying niggles...
Offline lch1
« Reply #6 on: 18 April 2006, 18:46 »
could be one of many things on abs but fear not !!!!!VAG codes will reveal all even an intermitant fault lets not hope it is the famous faulty solieniod on pump as could prove pricey as whole unit required but you should be able to feel ABS working when lights are not on as a slight judder under the foot pedal under normal braking conditions i hope i am not teaching you to suck eggs here!!! as not wanting to sound a know it all
regards lch1
« Reply #7 on: 18 April 2006, 18:55 »
That is 2 different cars  :grin:
By the way, you don't need VAG com to test sensors, just use a multimeter.
Offline Obvious
« Reply #8 on: 18 April 2006, 20:06 »
Quote
Thought I'd have the codes read anyway, for peace of minds sake. As I have few little things I want to try and sort out, so having them read could have led in the direction of sorting them or any problems I didn't know where there. Trouble with me is I tend not to live with problems, must be why my bank manager loves me  :laugh:
