Author Topic: Spare Wheel or Can of Tyre Foam??  (Read 3544 times)
Offline Megaos
« on: 16 April 2006, 20:00 »
   Just heard my gti (dbp, 18", centre arm rest, cruise, rcd500) is due to be built week 19 (week commencing 8th May) and it will take 3 to 5 weeks to get to the dealership (hoping it's 3). Is a space saver spare wheel supplied? A friend recently took delivery of his from a supermarket in Hull and he got a can of tyre foam instead of a spare wheel.
    I would think once you have used the foam, the tyre is thrown, so it's a new tyre every time you get a puncture!
Offline The Doc
  • E63s Estate - Vito Sport
Re: Spare Wheel or Can of Tyre Foam??
« Reply #1 on: 16 April 2006, 23:24 »
I got a space saver in my 2006 model Gti - delivered in DEC '05
Offline adw555
« Reply #2 on: 17 April 2006, 09:18 »
I have a spacesaver too...and according to the volkswagen website they all should have proper steel spacesavers..I'd go back to that supermarket and ask for my wheel  :wink:
Offline lowdown
« Reply #3 on: 17 April 2006, 11:12 »
Space saver supplied with my 1/04/06 car.
Offline Gene Hunt.
« Reply #4 on: 06 June 2006, 02:38 »
Never fit a space saver to a front wheel.  :wink:
Candy White ED35.
Offline Agreeable Slick
  • Unit
« Reply #5 on: 06 June 2006, 04:04 »
if you use tyre foam, you can only go 30mph tops anyhow.
space saver is the better way to go, although they are only good for 50mph.
Offline ChorleyGTI
« Reply #6 on: 13 August 2006, 15:01 »
Imports generally come with foam and inflator kit (like mine). Does anyone know where I can buy a space saver steel wheel kit for my mk V GTI. I have tried vw to no avail. Doc can you help?
Offline M Man
« Reply #7 on: 13 August 2006, 17:57 »
I got a normal good old steel wheel with a 225/45 on it! :laugh:
Offline ChorleyGTI
« Reply #8 on: 13 August 2006, 18:40 »
Thanks M Man, does it fit in the wheel space in the boot, where did you get it from?
Offline The Doc
« Reply #9 on: 13 August 2006, 21:44 »
VW will be able to get the parts.
Will you will need the full kit i.e. foam holder and jack etc?
Failing that my R32 is due for a chop soon... :wink:
« Last Edit: 22 October 2006, 13:32 by The Doc »
