Author Topic: wheels rubbing  (Read 945 times)
Offline nosaj26
wheels rubbing
« on: 16 April 2006, 17:17 »
ive just had golf mk3 gti lowered 40mm on koni ssk and it handles like an absolute dream ,plus i have 17's with 205-40-17 tyres,  however, if any body is in the back - even the lightest of people, the wheels will rub the trim slightly around the rear arches. this happens if i hit any bumps or dips in the road. this is proving to be a nightmare, and i assume could be quite dangerous? ive heard people talk about having the arches rolled, will this help? is it costly? what does this mean exactly and last of all where would i get it done? thanks
Offline Dizzie
  • Make friends with your fast
Re: wheels rubbing
« Reply #1 on: 17 April 2006, 12:36 »
rolling the arches is when you bend the lip of the arch that's on the inside up into the wing giving you more clearance on the outer edge when running bigger wheels.
Demontweeks will do them for £35/corner, but 2 years ago when i had mine done their work wasn't very good at all. The bodyshop I took the car to to get that vented wing done did the last of my 4 arches and their work was A+
as for the inside edge it's hammer time!
Mk4 Golf 150PD
Offline nosaj26
Re: wheels rubbing
« Reply #2 on: 18 April 2006, 18:49 »
cheers for advice il have a ring round local bodyshops, on my koni's they have adjustable dampers il try these as well se if it stops some of the bounce??????? hopefully wont ruin the ride
