Author Topic: Lowering spring kits ?  (Read 1998 times)
Offline Uruk Hai
« on: 15 April 2006, 21:35 »
I'm thinking of getting some new springs for my 91 8V as the old girl appears to be leaning a bit (suspected weak spring), I would like to lower it but only about 20 - 30 mm. Can anyone recommend some good value spring kits or should I just get new shocks and springs in one go and does any drop in ride height have bad effects on tyre wear or handling. Any advice appreciated thanks !
Offline takethefifth
Re: Lowering spring kits ?
« Reply #1 on: 18 April 2006, 14:12 »
I got a secondhand set of gmax 35mm ones that lower my 8v by a true 15mm.  Ride is not bad considering gmax are a cheap kit anyway, it does bottom out occasionally but seriously bumpy roads and its on 17's.  Cornering is great!  not got any feedback on tyres for you just yet!
Offline Fielder
« Reply #2 on: 18 April 2006, 14:37 »
i have a set of 6month old, hardly used lowering springs (-40mm) that came in the boot of my new GTI if your interested  :wink:
hahahaha fielders a c**k. sorry but he is just a tit. What a waste of forum space for that moron.
Offline Uruk Hai
« Reply #3 on: 21 April 2006, 10:30 »
Will that lower my G.T.I by 40mm or is that figure compared to a standard model ride height ?
Offline TwistedAspect
  • '89 Gti 8V - Diamond Black (RIP)
« Reply #4 on: 06 May 2006, 16:04 »
Personally, my set up works great as a budget buy....I am running Elbach springs on Boge shocks.....drop might be a bit severe for you though  :wink:
Offline Uruk Hai
« Reply #5 on: 06 May 2006, 21:38 »
I want to lower it but not so much that it badly effects the camber, I appreciate that any lowering is likely to have an adverse effect on tyre wear but I still want them to last as long as possible  :undecided:
