Author Topic: still paddling - boo hiss!  (Read 2114 times)
Offline sarben
« on: 28 November 2003, 17:15 »
just picked up my mkIII from the repair garage hoping (in vain) that the swimming pool in the rear passenger footwell had vanished.  (front footwell less deep - more like a paddling pool).  I'm told there aren't any holes in the floor.
But the chap reckoned that without removing the trim and front seat he wouldn't be able to pinpoint exactly where the leak was coming from.
Does anyone know of any obvious problems with water leaks that i could check out please?  and what is a drip tray?
Sarah
Offline Golfer
Re:still paddling - boo hiss!
« Reply #1 on: 01 December 2003, 09:09 »
Often due to blocked drainage / air vents.  Check the air vents are clear under the bonnet (at the back, just under the windscreen).  May need to remove a bit of the trim to reach them.   Leaks are also caused by sunroof's on many cars.  The sunroof channels water into odd places and floods the car.  Not sure if that's any use?
1998 Mk3 GTi 8v - now sold :(
2003 BMW 320d 150bhp now bought :)
2002 Seat Leon (almost a Mk4!)
Offline Onge
« Reply #2 on: 01 December 2003, 14:40 »
If the door seals are worn, water may be coming in from there. and ending up in the foot wells. This happened to my sisters car, changed the door seals now its sorted. Get someone to stay inside the car while you clean it with a jet wash. spray the water around the door area, the person inside the car should see if water is seeping through. If this does'nt work you will have a clean car - cant be bad
