Author Topic: turbo whistle  (Read 2088 times)
Offline craig g
turbo whistle
« on: 14 April 2006, 10:56 »
ive had my gti a few weeks but only just noticed the whistle when i had the window down is that right.
it is a progressive whistle !!
also at what revs does the turbo kick in
craig gTI
Offline Dizzie
  • Make friends with your fast
Re: turbo whistle
« Reply #1 on: 14 April 2006, 11:34 »
fit a boost gauge and you'll see the boost
otherwise around 2000rpm
Offline Flipmode
Re: turbo whistle
« Reply #2 on: 14 April 2006, 14:53 »
The whistle is normal mate, its the sound made by your dump valve and not really audible inside your cabin, just when u have your window down. It should be a clean crisp noise without any fluttering or jitters, otherwise you may be in need of a new valve, the factory Bosch? ones are made with a weak membrane so they don't last too long.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: turbo whistle
« Reply #3 on: 14 April 2006, 18:06 »
No, the diverter valve makes its' noise when you lift off the gas!!!
The whistleing noise is normal, Craig, & the turbo kicks in about 2.5k.
« Last Edit: 14 April 2006, 19:35 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Flipmode
Re: turbo whistle
« Reply #4 on: 14 April 2006, 18:21 »
oops! still learning  :embarassed:
Offline JonnoGti
Re: turbo whistle
« Reply #5 on: 17 April 2006, 11:56 »
Perfectly normal the whistle is! Like someone said you only hear it when the windows are down. I love the whistle myself!  :cool:
