Author Topic: Flashing temp gauge  (Read 2180 times)
Offline Deefadog
  • Mk2 16V (November 89)
Flashing temp gauge
« on: 13 April 2006, 16:46 »
Is the light on the temp gauge for the water temp?
As i just fitted a new temp sender and the gauge was working fine sitting half way, but every time i revved the engine with the accelerator the light would flash, if i pulled the choke out and revved it that way the light did not flash?
Any ideas?
Re: Flashing temp gauge
« Reply #1 on: 30 April 2006, 11:40 »
the light is either a temperature warning, or a level sensor warning.  Though I suspect if you have a choke, you dont have an in-tank coolant level sensor?
Offline Deefadog
« Reply #2 on: 30 April 2006, 11:44 »
No mate, no in-tank coolant level sensor
« Reply #3 on: 30 April 2006, 11:45 »
was it a genuine temp sensor, or a pattern part?
Offline Deefadog
« Reply #4 on: 30 April 2006, 11:47 »
GSF :( - so i am guessing ot's another dodgy sender from them!
« Reply #5 on: 30 April 2006, 11:49 »
I know their blue temp senders arnt any good!
Got any mates with a VW that you can pinch their sensor to test?  Or any good scrappies close by?
Offline Deefadog
« Reply #6 on: 30 April 2006, 12:02 »
Thanks
I got some off my valver that i change before, are the senders the same?
« Reply #7 on: 30 April 2006, 12:09 »
as long as its a black 2 pin sender they're all the same :)
Offline Deefadog
« Reply #8 on: 30 April 2006, 12:57 »
These senders are the single types and are all brass! I'll try them on it and see if that helps
Thanks
« Reply #9 on: 30 April 2006, 16:21 »
Ah, the 16v ones should work in that case :)
