Author Topic: k&n plus drilled air box  (Read 2258 times)
Offline snake16valve
« on: 12 April 2006, 20:42 »
Hi to all in the forum...
Can anyone tell me is it worth drilling my air box when i fit my new K&N pannel filter ?
My car is as follows-Mk 2 Golf GTI 1.8 16V....139bhp.
Thank's...for any info.
Offline Agreeable Slick
  • Unit
Re: k&n plus drilled air box
« Reply #1 on: 12 April 2006, 21:49 »
you will gain no performance from it, drilled or undrilled. Drilling it will give it a deeper throaty sound. Thats it.
Offline AudiA8Quattro
« Reply #2 on: 12 April 2006, 22:03 »
You will gain performance, but mainly mid-range, and a much better throttle response.
  • Unit
« Reply #3 on: 12 April 2006, 22:09 »
debateable. Nothing changed when i RR mine. Generally nothing to go mad about.
« Reply #4 on: 12 April 2006, 22:37 »
Probably very little bhp gain overall, probably about 2-3bhp on a standard mk2 16v, but as i said more gains mid-range, which is what a driver will notice more.
RR can change slightly on several runs, so testing with and without a filter won't really show much.
« Reply #5 on: 13 April 2006, 19:29 »
Ok m8 thank's for the info...sounds like to much hassle !
dont think i will bother...
Offline Simpson
  • one day il learn
« Reply #6 on: 13 April 2006, 23:35 »
i have just swapped mine over, best to find a second hand airbox froma scrappy and drill that and decide whether you like it, i have just done it and love the sound!
i must buy a new car!
Offline shaft69
« Reply #7 on: 14 April 2006, 01:09 »
Ive just bought drilled air box with afm and 2 month old k&n filter of ebay for £10, For my 8v. Taking of my green induction kit.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Gambit
« Reply #8 on: 14 April 2006, 10:15 »
@snake16valve - if you have the earlier airbox then you can just unclip the large section on the wing side of the airbox. if its a late airbox then you can pull the resonater tube out of the airbox - it slides (needs a good tug) out from the front of the box
Offline shaft69
« Reply #9 on: 14 April 2006, 12:43 »
Eurotek do those steove one off induction kits for 16v, They look the dogs.
184 Wallgate, Wigan
WN3 4AL
07966492823.
