Author Topic: its begun,  (Read 2100 times)
Offline Haribo!
its begun,
« on: 12 April 2006, 20:06 »
ive been busy today attempting to put my gti head on my driver and i have to say its gone very well so far, got it off, drilled the hole in the gti head for the coolant channel, bolted it all back together, then i snapped that bolt with the teeth that holds the alternator to the bracket..... so ill get another tomorrow and i should be finished, then i can see if its faster and also if ive missed anything and it blows up, i really should take a corse of some sort
Offline Tim-Mk2
  • now extra wide....
Re: its begun,
« Reply #1 on: 12 April 2006, 20:13 »
ah good luck!
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline Haribo!
Re: its begun,
« Reply #2 on: 12 April 2006, 20:18 »
cheers, im nackered, im not cut out for all this mechanic stuff, ide been at it for 8 hours strait before i decided ide done enuf and ached too much
Offline Tim-Mk2
Re: its begun,
« Reply #3 on: 12 April 2006, 20:30 »
haha well im sure it will be worth it in the end!
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline Haribo!
Re: its begun,
« Reply #4 on: 12 April 2006, 21:12 »
nah i reckon its gonna die on me, im convinced in fact
Offline Tim-Mk2
Re: its begun,
« Reply #5 on: 12 April 2006, 23:40 »
dont think like that!if i thought like that then mine would be even worse than it i now lol!
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline Haribo!
Re: its begun,
« Reply #6 on: 13 April 2006, 00:02 »
yours will be LOADS better when you buy those sill extensions off me  :wink: itll go faster too
Offline systemseiko
Re: its begun,
« Reply #7 on: 13 April 2006, 05:28 »
Haribo
           For someone that isn't a mechanic or minded U've done a decent job so far, hopefully all goes well,  on teh cambelt question i would cahnge it now prior to firing the plant up,  and while your at it change the tensioner as well :smiley:
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline Haribo!
Re: its begun,
« Reply #8 on: 13 April 2006, 11:01 »
Cheers systemseiko  :smiley:
right just picked up th efinal parts, timing belt, tensioner, carb mount and that bolt for the alternator, just need to stop being lazy and get my ass out side
Re: its begun,
« Reply #9 on: 13 April 2006, 11:09 »
Awesome, how hard was the coolant hole to sort?
Pics?
