Author Topic: VR6 suspension on a MK2  (Read 1356 times)
Offline maaarcooose
« on: 12 April 2006, 15:22 »
Can you fit shocks and spring sets designed for VR6 on a MK2.
Probably a dumb question.
!m!
« Last Edit: 12 April 2006, 15:25 by maaarcooose »
Offline A7 UFO
Re: VR6 suspension on a MK2
« Reply #1 on: 12 April 2006, 15:31 »
Hhhhmm, no.
« Reply #2 on: 13 April 2006, 11:21 »
Yes you can, provided you replace the top mounts too, same with Corrado VR6 suspension.  The low spec MK3s have exactly the same suspension setup (with different poundage springs), as does the Corrado.
BUT don't expect it to sit right as the VR is much heavier than the smaller lumps, though perhaps if you get coilover suspension you might just have enough adjustment to get the front low enough.
Offline A7 UFO
« Reply #3 on: 13 April 2006, 11:41 »
Your saying lowspec mk3 suspension is exactly the same as mk2 suspension (bar springs)?
« Reply #4 on: 13 April 2006, 11:53 »
I am indeed :)
Offline A7 UFO
« Reply #5 on: 13 April 2006, 12:03 »
Well I never knew that.  You learn something every day.
Offline maaarcooose
« Reply #6 on: 13 April 2006, 12:12 »
I thought the shocks looked the same.
Might buy the second hand VR6 set then instead of a new MK2 set.
Hmmmm.......
!m!
