Author Topic: In car water feature.....  (Read 2636 times)
Offline Dub_Dude_16v
  • Sunny Hertfordshire!
Re: In car water feature.....
« Reply #10 on: 12 April 2006, 09:39 »
Cool water feature!   :laugh:
Was it installed by Charlie Dimmok?  :grin: (dodgey spelling!) On the serious side that sucks mate! Hope ya get it sorted
Offline A7 UFO
« Reply #11 on: 12 April 2006, 10:00 »
I got a similar feature in mine, but it was from where the drainage hole had got blocked through to the wheel arch and the water was overflowing through the steering column.  Opened the bonnet, pushed the leaves and crud away from the hole and then got about 2ltrs of water onto my feet.
Offline Tim-Mk2
  • now extra wide....
« Reply #12 on: 12 April 2006, 16:39 »
ye done that waswell...
went to the car this mornin and looked at the front and it was fine really dry and i couldnt understand why it was so dry as it was alot wetter last nite.. i then realised that cous i had parked it on the road and not the drive it had all run to the back and made another puddle there! almost got it ALL out now!
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline Uruk Hai
« Reply #13 on: 12 April 2006, 17:23 »
Nothing wrong with a nice sauna !
Offline systemseiko
« Reply #14 on: 12 April 2006, 22:17 »
You should start breeding your own fish at this rate :grin: :grin:
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline Tim-Mk2
« Reply #15 on: 12 April 2006, 22:57 »
ah ye i know.. looked in there tonite and its ok i think... :undecided:
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline Tim-Mk2
« Reply #16 on: 12 April 2006, 22:58 »
gonna go to pet place tommoro and see what nice "golf" fish they have in stock!  :laugh:
« Last Edit: 12 April 2006, 23:00 by Tim-Mk2 »
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline [han]
  • Graphic Designer for Haribo
« Reply #17 on: 13 April 2006, 12:20 »
 :nerd:
Offline gillo_grumlin
« Reply #18 on: 20 April 2006, 18:02 »
Check the seal on the windscreen as well a little rot under there will let water in - but not that much. Looks like as above a problem with the drainage plug. Get some stiff but flexable wire or a thin plastic rod and push up from the wheel arch and then down repeat a few times and then flush through with a little water and see the crud come out (boiling water is good to start with or use some live yogurt as this will eat any leaf mulch / crud)
also greese any gromits near the drainage hole as the back wash probably got into the foor well through them. Also do it quickly as the water would also have dripped down the back of the fuse box - over time will cause problems with relays and wiring (one dead fuel pump relay in my own experience).
Offline Tim-Mk2
« Reply #19 on: 20 April 2006, 18:10 »
was none of these problems.... was the seal on the inner skin of the door card..  but ye thanks i had preveously tryed all these and had not solved the issue.. its all sorted now with new sponge underneath.. GOOD AS NEW
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
