Author Topic: Lights not working  (Read 1000 times)
2golfshis/hers
Lights not working
« on: 08 April 2006, 21:20 »
 :angry: changed bulbs on my wifes mk2 but she still aint got no reverse lights and fog lights any ideas? cheers
Offline Agreeable Slick
  • Unit
Re: Lights not working
« Reply #1 on: 08 April 2006, 21:29 »
reverse lights check that the connector on the gearbox is on ok, maybe give the connections a clean. Then check the fuses. Also are the fogs wired up? My bumper had fogs, but they were not wired up.
« Reply #2 on: 09 April 2006, 15:57 »
If its the rear fog that don't work, make sure your lights are on and you've clicked the fog light switch down 2 clicks ;)  For the fronts, make sure the wiring is connected to the spare plug under the header tank, someone I know wired them to the headlight leveling plugs  :grin:
