Author Topic: Lumpy idle & Vacuum Problems?  (Read 1294 times)
Offline Tornado
« on: 08 April 2006, 11:49 »
Hi there
Car is a 8v Digi. It has a lumpy idle but it pulls hard so who cares! However, when idling up to a junction or similar the brake pedal can go hard and the brakes almost don't work(no servo?).  Am i right in thinking that the 2 are related and could be vacuum problem?
Thanks
Alan
Ps has anyone used SP Performance for a cylinder head? Believe they are in North of England.  :smiley:
Lower!
Re: Lumpy idle & Vacuum Problems?
« Reply #1 on: 09 April 2006, 16:01 »
Check the chunky vacuum pope between the inlet manifold and the brake servo, there are a ew blanking plugs and a vacuum pipe attached to it, check the pipe itself and the blanking plugs for cracks.
If that don't help then it looks like the servo may be on its way out, its a costly part though so ideally you want a good second hand part.
Offline Tornado
« Reply #2 on: 09 April 2006, 23:48 »
Thanks RJ
I will have a peek during the week :smiley:
Alan
Do you really think that the Pontiff could be the source of these troubles?
« Last Edit: 09 April 2006, 23:50 by Tornado »
Lower!
Offline takethefifth
« Reply #3 on: 09 April 2006, 23:52 »
hahaha!
and how come you're being so rude about his weight problems?  :laugh:
Offline Tornado
« Reply #4 on: 10 April 2006, 00:09 »
Does this cassock make my bum look big :grin:
Lower!
