Author Topic: mk2 seats  (Read 2045 times)
Offline rwalker
  • '88 mk2 16v GTi (Sold) : '93 Corrado VR6
mk2 seats
« on: 07 April 2006, 13:21 »
Hey,
I want to change the seats for 2 reasons: so that I'm sitting a bit lower and I'm going to start making the interior shiny.  Has anyone got any suggestions what seats I can fit in?  Where does this leave me with the back seats because if I can help it I dont want to have to get them seperately apolstered to look the same?
- Ross
Life must be lived forwards but can only be understood backwards.
profile on corrado database
Offline TIM20
Re: mk2 seats
« Reply #1 on: 07 April 2006, 15:47 »
you can put a full carrado interior in, but not the door cards.
The front seats are set a bit lower and just slot in bu the backs need a little bit of fiddling.  Nothing too hard though just a couple of brackets making up,
means you will sit lower and the seats will match
Hope this helps
Tim
Offline Dizzie
  • Make friends with your fast
Re: mk2 seats
« Reply #2 on: 09 April 2006, 14:40 »
to install a corrado rear bench you'll need to extend the pins where they lock onto the sides and weld in a few brackets for them to attach to the floor. You can fit them in without the welding, but it's not very secure for rear passengers when their seat slides away from under them under heavy braking!
fronts bolt straight in afaik
Offline Gene Hunt.
Re: mk2 seats
« Reply #3 on: 04 June 2006, 06:08 »
Don't think it would pass the m.o.t like that either.
Candy White ED35.
