Author Topic: Rallye Questions...  (Read 2086 times)
Offline knobby
Rallye Questions...
« on: 04 April 2006, 21:39 »
Hi
Ok i think ive found a Rallye.. Just got a few questions first...
The one i have looked at has a small amount of rust on the sills, its only surface rust, is this normal and any ideas of cost of repair?
The front arches have been cut, the lip that the arch would usually have has been cut away and on one side the tyre has caught the wing, its started to rust slightly and its bubbled in one place. is it normal for Rallyes to have there front arches cut, or for them to rust, How much would a repair be? Could it be repaired?
Where the car has been jacked under the car, it looks like the floor has slightly caved in, ive never seen another rallye so i dont know if this is there normal look. Any advice welcome.
I hope i have found a good one.
Knobby.
Old VW's never die...they just go faster!
mix
Re: Rallye Questions...
« Reply #1 on: 04 April 2006, 21:49 »
to me, someone who doesn't know much about ralleyes, that sounds like a dodgy one....
try looking HERE for some ralleyes etc, you have to check back once in a while, they haven't got a ralleye in at the mo...
Offline knobby
« Reply #2 on: 04 April 2006, 21:53 »
I'm being proper fussy...   :wink:
I just need some opinions of someone that has a Rallye, the guy seems spot on, it runs well, and overall the car seems like a good one.
Knobby
mix
« Reply #3 on: 04 April 2006, 21:55 »
well...you fussy sod....someone will be along soon to lend a helping hand
*looks in martz direction*
Offline knobby
« Reply #4 on: 05 April 2006, 12:33 »
help guys....  :cry:
« Reply #5 on: 05 April 2006, 12:54 »
I think the sills are a weak spot on the rallye, they're metal arnt they?  As for the floorpan it is the same as a normal MK2 so if its caved in it shows someone wasn't taking enough care when jacking up the car.  Have a close look at the arches and decide if they're savable, as finding replacement Rallye wings wont be easy!
I'd have thought the cutouts would be normal since I imagine it was designed for wide wheels from the start?  Do the cutouts look identical either side?
Offline Agreeable Slick
  • Unit
« Reply #6 on: 05 April 2006, 14:04 »
The sills are a weak spot on rallyes, i have seen a few that have started to bubble and need some work doing on the soon. As for the arches, i am not sure that they are meant to be cut, as the blown wings should have made space for the wheels and not required cutting. Jacking point as jonny has said is definately the same as a mk2 floorpan so someone has been careless lifting it, no doubt a garage at some point.
Regarding some more info, you can try pm'ing:
JV
Toph
Martz
as they all have rallyes on this site.  :smiley:
Offline knobby
« Reply #7 on: 05 April 2006, 15:35 »
Hi
Thanks for the advice. to be honest i think i am just being a little too fussy. its a 17 Year old car, its bound to have some rust. The arches are not bad, was surprised to see them cut. I know std mk2's are cut all the time. Like you i thought the rallye arches were much wider.
I'm getting a little parnoid about spending 5k on a 17 year old car. Its gonna need some money spending on it i guess.
Was f&cking nice  :smiley:
Knobby!
Offline yorkie
« Reply #8 on: 05 April 2006, 19:33 »
Where on the sills is the rust?
Is it exposed or showing as bubbled paint?
Sills are no longer available but a decent body shop can repair them.
Are the arches cut away or is the lip just rolled which is quite common - either way repairable.
The floorpan is not the same as a MkII, where is the dent?
Offline knobby
« Reply #9 on: 05 April 2006, 19:40 »
Hi
thanks for all the advice.... I didnt think the floor plan was the same.. i was told something to do with Corrado front subframe. The dent on the floorplan is close to the front arch. Where the wing ends.
I think it is just careless jacking. just wondering if someone would be able to repair this?
Knobby
