Author Topic: strange noise  (Read 2589 times)
Offline Leejaydoob
strange noise
« on: 26 November 2003, 23:38 »
just managed to get a drive in my mk2
when acclerating i was getting a loud clunking noise and a kind of clicking noise coming from front driver side
on inspection found k+n air intake had worked loose and was hitting bonnet on accleration but the clicking noise is still there
if i push down on suspension there is a noise as suspension settles but only on the drivers side
any ideas anyone?
Offline Helios_Blue_Valver
Re:strange noise
« Reply #1 on: 27 November 2003, 02:46 »
ball joint or upper strut mount perhaps?
Blue MK2
Re:strange noise
« Reply #2 on: 27 November 2003, 11:00 »
CV joint? does it go 'click, click, click'?
Offline Leejaydoob
Re:strange noise
« Reply #3 on: 27 November 2003, 11:23 »
no not a cv joint noise, more suspension noise
the car appears to wander a little when driving as well
Offline Gambit
Re:strange noise
« Reply #4 on: 27 November 2003, 11:29 »
id go also with the top mount being knackered
does it only happen when you set off?
if u get it when u start the car also it'll be a knackered engine mount
golfvr6
Re:strange noise
« Reply #5 on: 28 November 2003, 00:11 »
Wishbone bushes probably. Also check suspension balljoint, top mounts and wheel bearings.
Offline Leejaydoob
Re:strange noise
« Reply #6 on: 28 November 2003, 00:22 »
cheers guys
ill check them all out
