Author Topic: brakes  (Read 1190 times)
Offline GolfGL
brakes
« on: 03 April 2006, 21:20 »
ive been getting a judering through the brake pedal at speeds and now the check brake pad light has come on. How much should i be paying for a set of brake discs and pads for the front of a 2.0 gti 99 APK?
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: brakes
« Reply #1 on: 03 April 2006, 22:35 »
www.buypartsbuy.co.uk
On my 1.8 T, 2 discs & one set of pads (front) would cost £67.** inc. carriage.  (I can't imagine yours being anymore than that).  Get 'em checked though, as you may only need pads.  Also, check your rear discs/pads, as these could be shagged without you knowing, due to their being only 1 brake pad sensor which is located on the N/S front hub area.  :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GolfGL
Re: brakes
« Reply #2 on: 03 April 2006, 22:38 »
Will do, but as i have juddering through the pedal im guessing discs are warped plus they have a thick rustly lip so probably been on there since new.
Re: brakes
« Reply #3 on: 03 April 2006, 22:53 »
I suppose at £17 a disc, you might as well change them, then, seeing as you'll be half way there already when you change the pads.  You doing it yourself?  It's a fairly straightforward job, TBH. :smiley:
