Author Topic: 2.0l conversion  (Read 1868 times)
Offline rowlers
  • I'm back - MK7 GTI
2.0l conversion
« on: 31 March 2006, 16:59 »
right all read loads about throwing a 2.0 bottom end to my valver, but....
What is the best bottom end to use??
Iv'e read abf, 9a 3a and who know what else.
What is the easiest most straightforward swap
Whats the tall and short block?
I'm guessing a new manifold/downpipe would be needed for a tall block???  :huh:
Re: 2.0l conversion
« Reply #1 on: 31 March 2006, 18:25 »
They all will work just as well.
The ABF is a tall block, which means literally that its a bit taller ;)
Audi blocks are short blocks as is the 9a fitted to the Passat & Corrado I believe.
With an ABF you may have a problem with the throttle body touching the bonnet, but a few taps with a hammer sorts this out.  You also may get contact between the zaust & tunnel, again a few bashes with a hammer will sort this.
The other option is to modify the front engine mounting to tilt the engine back a little, or get a spacer for the zaust manifold -> downpipe.
With the short blocks its a case of bolt on and forget, but if you go for an Audi lump you have to swap all the anxileries over from your old 1.8 lump.
« Last Edit: 31 March 2006, 18:26 by rubjonny »
Offline rowlers
Re: 2.0l conversion
« Reply #2 on: 31 March 2006, 19:42 »
so I could get a 9a from a passat or rado and this will bolt straight on?
this is what I shall search for!
Re: 2.0l conversion
« Reply #3 on: 31 March 2006, 19:51 »
Yup the 9a is the same height as the KR :)
Offline MackyM
  • Rollin' back the years...
Re: 2.0l conversion
« Reply #4 on: 02 April 2006, 21:06 »
Let me know if you find more than one  :smiley:
Veedubgt18v
Re: 2.0l conversion
« Reply #5 on: 02 April 2006, 21:07 »
yup me 2 lol well badly wanna capacity increase........... :grin:
Offline SarahD
Re: 2.0l conversion
« Reply #6 on: 04 April 2006, 10:24 »
im in middle of taking my 2.0 out and replacing it with a 1.8, more hassle than its worth i tell ya  :cry: my wiring harness has been hacked to fookin pieces, oh the joys of cars  :evil:
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: 2.0l conversion
« Reply #7 on: 04 April 2006, 10:41 »
What was the hassle? What 2.0 engine did you end up going with?
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline SarahD
Re: 2.0l conversion
« Reply #8 on: 04 April 2006, 11:07 »
im having problems with my immobiliser, everything else is pretty much easy  :grin: and ive put the 1.8 8v back in it, the 2.0 was sh!te and totally foooked
Offline Madone_si
Re: 2.0l conversion
« Reply #9 on: 04 April 2006, 11:33 »
rrrrrrrrrr - immobilisers bloody nightmare they can be...
SOLD - BLACK SOY 92
