Author Topic: Wheel refurbishment  (Read 3323 times)
Offline JezGTI
Wheel refurbishment
« on: 26 November 2003, 15:39 »
Any recommendations for places that do alloy wheel refurbishment.  I'm in Manchester, somewhere local would be ideal.
Offline 15 inches
Re:Wheel refurbishment
« Reply #1 on: 26 November 2003, 21:42 »
Do it yourself.
If you want em mint' then get em sand blasted,and simply prime,paint and laquar the blighters.
If they arent in that bad you can get a ;dremil' mini sander on em..
Offline wheelrefurb
« Reply #2 on: 29 November 2003, 16:27 »
I've got to disagree on that one. If you want them to look good and last get them done properly. Make sure they are stripped back to a bare metal finish and are painted with powder coat, the thickness of paint and durability is not something you are going to be able to match yourself in a wet paint. I don't know of anyone in the Manchester area, and I'm a long way from you, but as a guide I'd only charge you ?20.50 a wheel for this on a 15" rim.
Good luck.
Offline Helios_Blue_Valver
« Reply #3 on: 29 November 2003, 17:41 »
Good luck.
I have to agree here. I refurbed a set my self a few years back. no matter what I did the paint kept craking and flaking and falling off. I tried putting a flex agent into the paint before spraying and it still flaked off within a month. Once I had them powdercoated I never had another problem with them.
Offline modulater
« Reply #4 on: 01 December 2003, 01:34 »
Do it yourself.
I didnt think you could sand blast alloy wheels as this would take surface metal away, and you only do it on metal wheels.
Alloy wheels are normally acid tank dipped to remove old paint and then put on a lathe with a diamond tip to repair any kerbing marks.
I have a mercedes coachworks next door to where I work and they use a company called spit and polish.
Offline JezGTI
« Reply #5 on: 01 December 2003, 19:22 »
Thanks guys, I have emailed spit and polish to see what price they would charge.
Offline stevie j.
« Reply #6 on: 06 December 2003, 14:04 »
theres a place in morley (near leeds) just off the m62 that charges about ?40 a wheel inc. refit and balance of tyre there not the cheapest but they do a top job I'll dig the number out if your interested m8?
old_boy
« Reply #7 on: 07 December 2003, 21:01 »
If anybody is in kent, i would'nt recommend going to a place called le$!*&s.
unless of course you want your pirelli alloys touched up with black marker pen!
i kid you not! >:( :o :(
