Author Topic: Ignition Barrel Wiring  (Read 876 times)
Breaker
« on: 29 March 2006, 17:49 »
does anyone have a diagram or a photo showing which colour
wire goes to what terminal on the back of the ignition barrel ie(where the key goes in)
tried haynes but i can find it in there let alone work out where the wires go!!
Offline systemseiko
Re: Ignition Barrel Wiring
« Reply #1 on: 30 March 2006, 01:07 »
Take it U got your car stolen or broke into,  currently working nights but will post you tomorrow when i get home.
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
« Reply #2 on: 30 March 2006, 09:42 »
30- Red - Battery positive feed
50- Red/Blk - To starter motor
X - Blk/Yel - x-over relay feed
15 - Blk - ignition live
Late MK2s only
S or SU - Brn/Red - (key in ignition feed, only on late MK2s & often not connected)
Breaker
« Reply #3 on: 30 March 2006, 15:29 »
there is no connector on my ignition so the wires are just all
seperate.
cheers for the colours but which pins do they attach to?!?!
« Reply #4 on: 30 March 2006, 15:52 »
The pins should be labled on the ignition switch, as I've pointed out.  If not chop an ignition switch of a car in the scrappy and splice it in ;)
