Author Topic: ABS Brakes  (Read 1204 times)
Offline ibmike
ABS Brakes
« on: 29 March 2006, 14:13 »
Right to cut a long story short
I have a fault on my abs which indicates the front right sensor is faulty
Unfortunatly its not the sensor or the wiring its the actual modulator itself
Anyway i have the modulator and am going to be changing it this weekend just wandering if anyone has done one before and is there any special way of bleeding it because of the abs or do you just bleed it as normal
Thanks
Offline monkeyalan
Re: ABS Brakes
« Reply #1 on: 29 March 2006, 19:18 »
modulator? do you mean abs pump/ecu?
Offline ibmike
Re: ABS Brakes
« Reply #2 on: 30 March 2006, 09:43 »
Yeh thats it
Offline monkeyalan
Re: ABS Brakes
« Reply #3 on: 30 March 2006, 12:17 »
I think you just bleed them as normal. I also had a fault code that read ABS pump but it turned out to be both front sensors
Offline ibmike
Re: ABS Brakes
« Reply #4 on: 30 March 2006, 16:11 »
Well this is defo an internal fault on the abs ecu
All sensors and wiring are with in the recommended specs
