Author Topic: Car starts when it wants!!!!  (Read 3529 times)
Offline GTI16vGaz
  • New car will be displayed soon.
« on: 26 November 2003, 09:03 »
Hello..
Another question..
I have bought a mk2 16v GTI and i'm having a little problem with it starting, when i first bought the car on Sunday it started fine every morning up until today, the battery has loads of life init and the car is ticking over fine but not fireing up!! so i left it 2 mins and tried again, the car then fired up but very slowly, the revs went from 200 then to 300, 400, 500 etc.... 10000 but took about 5 seconds, usually it will fire up and the revs will go stright to about 1500 then come back down...
Its anoying me as the rest of the car is mint, i don't know if its going to start in the morning any help wouild be great.
The car is a black mk2 GTI 16v 1989, 90000 miles. F plate...
Thanks
Garry
Offline richandhazel
Re:Car starts when it wants!!!!
« Reply #1 on: 26 November 2003, 09:07 »
Just wondering if the damps got into it with all this rain. Might be worth checking your distributer cap, leads etc. :-\
Offline GTI16vGaz
« Reply #2 on: 26 November 2003, 09:09 »
Its strange tho cos the other morning when it was frosty and really cold the car started with out a problem at all... wonder if the damp over the last couple of days has effected it...
thanks rich...
Offline GTI16vGaz
« Reply #3 on: 26 November 2003, 09:24 »
Any more idea's lads....   ;)
Offline Gambit
« Reply #4 on: 26 November 2003, 09:24 »
mine has this problem also, takes an age to start in the morning, but once its started its fine
i find that at first if i let it turn over a couple of times, then iginition off, then turn over again it will start immeaditily
ive been told that its something to do with the injectors being old & knackered - something to do with the pressure in the lines after being left overnight
« Last Edit: 26 November 2003, 09:28 by Gambit »
Offline GTI16vGaz
« Reply #5 on: 26 November 2003, 09:34 »
Ok thanks for that... is there anyway of resolving the problem.. cleaning the injectors? etc....?
Offline Gambit
« Reply #6 on: 26 November 2003, 09:42 »
new ones
Offline AL16v
« Reply #7 on: 26 November 2003, 13:01 »
Sounds ignition rather than fuel related.  Dizzy (Hall sender ?), plugs, leads.
Is it misfiring when it starts at really low revs ?
* 94 Audi Coupe 2.6 V6 *
_88 Mk2 Golf GTI 16v_
Mongoose Stainless Steel System
256mm Brake Conversion
Boge Springs Spax Gas Shox
Full Leather
= 99 Bora V5 =
Jazz Blue, totally standard.
Offline danhock
« Reply #8 on: 26 November 2003, 13:03 »
Could be fuel related..
Try turning the ignition on. Leave it 10 secs. Pump the pedal a couple of times then fire it up...
Thats what mine needs to start in the mornings!
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Blue MK2
« Reply #9 on: 26 November 2003, 13:08 »
I also had that problem. Turned out to be an electrical fault in the engine. That thing on the starter motor blew up after a month :(
