Golf mk2
rubbing noise when turning left,
Topic: rubbing noise when turning left, (Read 1387 times)
Simpson
one day il learn
27 March 2006, 14:53 »
my golf gti 8 valve, has is making a stranmge rubbing like noise when the steering wheel has no resistence to the left, any ideas? likely wheel bearing? i have just replaced the drivers hub and bearing which cured another problem now i have this, alos my power steering becomes heavy, is this the pump on its way out?
cheers
i must buy a new car!
[han]
Graphic Designer for Haribo
Re: rubbing noise when turning left,
27 March 2006, 14:56 »
a rubbing not a squeel?
Judderi
Guest
27 March 2006, 14:57 »
Its most probably just your pas belt. It may need replacing or simply tensioning.
Simpson
one day il learn
28 March 2006, 09:53 »
no its kind of like as though something is catching, like a very fine vibration as though the tyre is catching on something but i cant see how it is. Cheers anyway
MR.V
Just got here
28 March 2006, 23:35 »
ha ha i had this searched high and low for it turns out the steering rack was'nt aligned causeing the wheel to rub on the inner arch spent ages lining it up then next mot had to change the track rod so had to have it all apart again!!!
Agreeable Slick
Global Moderator
Serious forum addict
Unit
29 March 2006, 01:41 »
check your camber and tracking as a first point of call, and then move onto things like steering tack etc. The most i reckong it will be is the camber on the left strut is ouit of postion. Have you changed the tyres or wheels recentey?
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
Dizzie
Forum addict
Make friends with your fast
Reply #6 on:
29 March 2006, 13:32 »
one way to see if the pump is working is just look in the resivoir if you have the box type one. you'll see if sloshing around in there as it's been cycled throught the pipes.
Mk4 Golf 150PD
Simpson
one day il learn
Reply #7 on:
30 March 2006, 17:43 »
cheers for the help i was thinking possible track rod as i have just had that out when i changed the hub, also i have changed all the wheels recently too. thanks
Golf mk2
