Author Topic: Break lights dont work?  (Read 1494 times)
Offline Danny
« on: 27 March 2006, 04:01 »
So my Cabby is coming along. I need some suggestions on what could be checked or replaced. My regular lights work in the rear but when i apply the breaks the lights dont brighten red? What can be some things to check? Thanks.
No DuB should die.
Offline amzee
Re: Break lights dont work?
« Reply #1 on: 27 March 2006, 19:34 »
should be a switch on the brake pedal at the top of it might have come off or faulty oh an i think there is a fuse to check that
Offline Danny
« Reply #2 on: 28 March 2006, 03:49 »
Ok I'll check that. Is there a kinda switch behind the break pedal?
No DuB should die.
« Reply #3 on: 13 April 2006, 16:26 »
I think the switch might be on the brake servo itself, though I could be wrong.  On a MK2 its defo on the pedal so it might be on a later cabby as well :)
I had the same problem and it turned out to be 1 duff bulb and 1 bad contact, cleaned both bulb trays up & fitted shiny bulbs and all was well :)
