Author Topic: No fuel to fuel filter mk1 gti  (Read 2431 times)
Offline mr2turbo
« on: 26 March 2006, 19:26 »
As above really but when you turn the igntion on you can hear the fuel pump gas up it also stays like that when cranking, but theres no fuel getting to engine bay (main feed pipe to fuel filter cracked of to check) so i just wondered if there was a common problem that people might know of ? Its a 83 gti
Thanks peeps.
Offline x5pea
  • www.mk1golf.co.uk
Re: No fuel to fuel filter mk1 gti
« Reply #1 on: 28 March 2006, 10:24 »
Check the line arent block from the tank
The sender unit is doing its job
pump is pushing thro fuel...
I you are stuck buy a £2 clear filter and some rubber fuel lines and and connect it just the other side of the sender unit as a test to see if the petrol is moving thro.
As i mentioned elsewhere replace the cheepest things first if you cannot identify the fault, filter, pump, sender unit, ect
03 BMW X5 - Daily Runner
83 Mk1 GTi - Project car
www.mk1golf.co.uk
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #2 on: 28 March 2006, 13:28 »
This might help... I've got same engine as yours..
http://www.golfgtiforum.co.uk/index.php?topic=31094.0
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
