Author Topic: Cant open my boot please help  (Read 1028 times)
Offline dan the man
« on: 26 March 2006, 14:45 »
 :sad:Went to asda last night and when i came to put the shopping in the boot it wont open!All the doors are unlocked with the key fob but the boot refused to budge.I know there is a common fault with the mechanism but i had a look when i got home,removed the boot lock cover and had my girlfriend try to open it so i could see whats happening and it wasnt releasing its self so is there damage to a cable or something.I really need to get it fixed because im supposed to be picking up my girlfreinds parents from the airport and i cant see em trying to squeeze the luggage into the boot with the back seats down! :lipsrsealed:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Cant open my boot please help
« Reply #1 on: 26 March 2006, 15:41 »
I'm not taking the p*ss, but are you sure someone hasn't just deadlocked the boot with the key???
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dan the man
« Reply #2 on: 26 March 2006, 17:10 »
Sorry, i forgot to mention the lock wont turn on the outside either
Offline rob__gti
« Reply #3 on: 28 August 2009, 20:19 »
i have the same problem too, also the key wont turn in the lock.
how are/is the 'deadlock' applied??? i;ve only owned the car 12 days!!
thanks in advance
Offline Rhyso
« Reply #4 on: 28 August 2009, 20:22 »
sounds like
a) microswitch has failed
b) lock has corroded
both are common faults
not quite sure how you get around it though  :undecided:  could try thumping the boot lock area to see if the switch starts working - at least long enough to open the boot and get it repaired  :undecided:
