Author Topic: HELP! No interior Lights  (Read 1300 times)
Offline Tim-Mk2
  • now extra wide....
« on: 26 March 2006, 13:15 »
i replaced my speedo clocks with rev counter 1's and all interior lghts were working fine... now as its all back togeter using same bulbs as i had in the originals as knew they worked... none of my interior lights work...just took the light switch out to look at it and put my lights on to test.. they were fine so switched them off
So...
My headlights and tail lights work fine
My clocks (speedo, rev, fuel, temp and all the small bulbs in the middle) work
All the switches work but....
all the lights that lights the speedo and swithches (exept the orage 1's that twell u awitch is on as they work) dont work!
have taken fog light swith apart and found that the main green bulbs has blown.. this is also the case for the speedo clocks but they worked before i put them in... i believe that this will be the case for all the bulbs. I have checked the fuse but i dont know how to tell if it has blown or not as its a 15amp and it seems to have no fuse wire!
the earth claw has also been suggested to me but i cant seem to find any main earth cable by my fuse box!
any help is very much appreciated!
Tim.
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Veedubgt18v
Re: HELP! No interior Lights
« Reply #1 on: 26 March 2006, 16:12 »
its right up behind it you have to more or less remove the fuse box to get access. pull out the 2 white clips on eiother side and it rotates forward. then they will be up above that. follow the brown wires
