Author Topic: 8v GTI convert to Carb?  (Read 832 times)
Offline Kinetic Dan
« on: 26 March 2006, 03:22 »
As I cant seem to get my 8v KJet to run, I'm thinking of making things simpler and converting it to a Weber carb.
What parts to I need, and what work is required to be done?
Thanks!
Offline Devon Joe
  • Liebe zum ropey Automobil
Re: 8v GTI convert to Carb?
« Reply #1 on: 26 March 2006, 12:19 »
do you mean the weber that replaces the standard pierburg on 1.6/1.8 carbed Golfs etc?
if so i think youll need a fuel pressure regulator like a Filter King to drop the high GTI pressure down for the carb- the 1.6 etc have a simple low pressure mechanical fuel pump on the engine block.  the carb should come with an alloy adapter plate and new studs (check these are there if you buy a 2nd hand one!) and youll need the inlet manifold off a 1.8 driver or gl to fit your GTI head. youll have to route the choke cable into the car but the dash has a blanking plate for it anyway. probably pick the lot up from a scrapyard for a few quid!
the weber 2e2 replacement is a good choice- my old 1.6cl was transformed when i fitted one :smiley:
If only my Volkswagen was as reliable as everyone else's...
Offline shaft69
« Reply #2 on: 26 March 2006, 15:08 »
What about to single weber/dellorto dcoe 45 or 48 carb on lynx manifold? :smiley:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
