Author Topic: 1.3 mk1 engine mount relocation  (Read 3190 times)
Offline MR.V
« on: 25 March 2006, 01:07 »
hi guys is there any chance of any pictures or tips on how to fit a 1.8 mk2 card engine in a 1.3 mk1
i know the engine mounts need to be changed but i need to know where they shoud be located in the engine bay
any help would be great
jon
Offline x5pea
  • www.mk1golf.co.uk
Re: 1.3 mk1 engine mount relocation
« Reply #1 on: 28 March 2006, 10:20 »
I did this coversion many years ago... al hunt out some pics....
Only needs one mount changed drop out the old engine pop in the new one secure the first two mounts and mark out the 3rd, Remove the engine again weld the mount then refit the new engine again. Thats the way i did it be be on the safe side,
Al get back to you with pics if i can find them
03 BMW X5 - Daily Runner
83 Mk1 GTi - Project car
www.mk1golf.co.uk
Offline MR.V
« Reply #2 on: 28 March 2006, 23:27 »
mint!! i thought it was a real arse of a job it don't sound too bad !
do you know which engine mounts gotta be moved ?
can a use the old one that i cut off of is it best to get a Mk2 mounting point (i have a Mk2 shell) and graft it on?
thanks for the response so far !!
Offline ManicGTI
« Reply #3 on: 01 April 2006, 01:11 »
Its the Driver side mount., you need to cut it off, invert it 180 degrees and weld back onto teh chassis leg.  Theres a notch in the mount that lines up with a crease in the chassis leg itself  :smiley:.
Ask Mk1_Driver (James) on CGTI, hes got pics as he did small to large block conversion on his :)
