Author Topic: mk3 engine swop  (Read 964 times)
Offline Seth
mk3 engine swop
« on: 23 March 2006, 22:02 »
How easy :smiley: or hard  :sad: would it be to put a vr6 engine in my mk3 gti 8 valve does anybody know I been offered 1 from a corrado thats been rear ended and as my engines dead I figured it might be wirth lookin into
AKA VEEDUBJUNKY
Offline Dom Mk3
  • Insert wit here
Re: mk3 engine swop
« Reply #1 on: 23 March 2006, 22:32 »
it'll drop in, but you'll need the usual conversion stuff... gearbox, ecu, loom, clocks?
mowgli
Re: mk3 engine swop
« Reply #2 on: 24 March 2006, 09:00 »
BRAKES!!!  :shocked:
Oh, and uprated front springs, a set of second hand front struts off a VR6 would do nicely.
Offline ...joe
Re: mk3 engine swop
« Reply #3 on: 25 March 2006, 11:11 »
should be easy as they made a vr6 golf so plenty of parts available. anything you cant get off the 'raddo can be found in a scrappy if your lucky. definately need brakes and shocks to take the extra weight!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Dizzie
  • Make friends with your fast
Re: mk3 engine swop
« Reply #4 on: 25 March 2006, 17:13 »
aren't the mk3 8v brakes the same as the VR6 ones anyway? 288mm?
the boys at DUBusiness up the road from me are doing this conversion. they had a VR6 vento which they removed all the bits needed.
The VR6 gearbox is cable whereas the 8v is rod. simple to convert though.
Mk4 Golf 150PD
