Author Topic: holes in mk1 gti  (Read 2023 times)
Offline amzee
holes in mk1 gti
« on: 23 March 2006, 12:59 »
ok dont no if this is the right place to post this
any had a good look around my new car an i have found two holes
tyre well
and on the front drivers side wing nr the sill
now what is the best method to repair these areas ?
thanks
amzee
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: holes in mk1 gti
« Reply #1 on: 23 March 2006, 14:26 »
the spare wheel boot area is a simple one, cut and sand down the area until there is not rut and weld in new metal. The picture at the sill - I can't figure out where that is - do you have a better picture a bit further away?
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline amzee
« Reply #2 on: 24 March 2006, 11:55 »
ok cool
heres a pic of the wing one
the hole is under where the wing meets the sill
thanks
Offline Madone_si
« Reply #3 on: 24 March 2006, 12:17 »
seems to me that your inner sill is rotten there and will require replacing and the a front lower part of that front wing it rotten too - sill part is a bit of a nightmare but repairable - front wing lower part easy to do as its underneath - again cut away rotten parts and weld in new metal. I would get the sill part look at though as its gone all the way through.. you might find that the sill on that side is rotten along the door shuttle part as well.
SOLD - BLACK SOY 92
