Author Topic: Alarm beep  (Read 4214 times)
Offline welshgar
Re: Alarm beep
« Reply #10 on: 31 March 2006, 19:16 »
my m8 in work, bought a 5dr 1.8T....his key only opens the drivers door???? can Vagcom sort that???
^^ i quite fancy losing the one door opening gimmick too!
Mk4 GT TDi::RS4's::weitec coilies::RCCR::polo mirrors::cream leather::
MK1 1.5 GL Auto restoration....coming along slowly :-(
its not the winning that gives me pleasure....its the taking apart
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Alarm beep
« Reply #11 on: 31 March 2006, 20:13 »
Unless you get access to VAG-COM, then you'll just have to keep double pressing the fob for passengers. :sad:
It wouldn't be that bad, but not every 'double press' works.  You can need 3 or 4 attempts, sometimes.  :angry:
My mrs just stands there with a look of disgust, as if I'm keeping her out in the cold on purpose! :grin:
« Last Edit: 31 March 2006, 21:58 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Mantamad
Re: Alarm beep
« Reply #12 on: 31 March 2006, 21:16 »
I also have a Discovery which has the same arrangement so I am used to it - still don't care for it though.
Black 2002 GT TDi 130
Offline welshgar
Re: Alarm beep
« Reply #13 on: 01 April 2006, 09:24 »
Quote
Quote
hahaha, must be a girl thing then...mine does the same  :grin:
especially in the rain..hahahahaha
kingturbo
Re: Alarm beep
« Reply #14 on: 01 April 2006, 12:36 »
Quote
Quote
ha ha same as my mrs but when i press mine 3 x it opens the windows too
Offline Mantamad
Re: Alarm beep
« Reply #15 on: 01 April 2006, 19:54 »
3 x and the windows open..........must try that
Say bye bye
Re: Alarm beep
« Reply #16 on: 01 April 2006, 21:56 »
3 times and the windows open?!?!!?!  :undecided: not on mine it dont  :huh: if you put the key in and unlock the car and hold the key in the unlock position then all the windows open same if you lock the car with the key and hold it there the windows close, my fob wont operate the windows, need to mess round with vagcom for that  :undecided:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Alarm beep
« Reply #17 on: 02 April 2006, 10:19 »
and you will need additiional wiring in the car too, the kit is about £100 and then the windows will open/close or vent, so will the sunroof :cool:
Say bye bye
Re: Alarm beep
« Reply #18 on: 02 April 2006, 12:35 »
i thought these cars come with the wiring?
Offline GazB
Re: Alarm beep
« Reply #19 on: 02 April 2006, 14:29 »
not sure on all models, looked into ot on mine 2002 aum and i need to fit additional wiring harness apparently :undecided:
