Author Topic: Bleeding Broken Brakes  (Read 4380 times)
Offline AL16v
« on: 24 November 2003, 22:13 »
I've seen posts along similar lines before but never really found a definitive answer.
Set up is as follows:
256mm fronts (from a '91 Jetta)
22mm master cylinder (new)
Standard rears (new discs and pads)
After bleeding the brakes several times (with load adjuster clamped in position and rear jacked up high) my pedal is still fairly spongey.  I have clamped the hoses in turn and isolated the problem to the rears.
I have had the calipers off and tried (best as I could) to follow the Haynes procedure for bleeding the calipers before refitting.
Any ideas for getting my pedal feel back ?
* 94 Audi Coupe 2.6 V6 *
_88 Mk2 Golf GTI 16v_
Mongoose Stainless Steel System
256mm Brake Conversion
Boge Springs Spax Gas Shox
Full Leather
= 99 Bora V5 =
Jazz Blue, totally standard.
golfvr6
Re:Bleeding Broken Brakes
« Reply #1 on: 25 November 2003, 00:01 »
Jack the rear up as high as you can, pump the brake pedal about 40 times, then leave it to settle for half an hour then bleed the backs again. Do you keep get air bubble out of the back calipers when bleeding? or is the fluid clear?
Offline AL16v
« Reply #2 on: 25 November 2003, 12:47 »
I'm not getting any air out at all - which is the problem.
The fluid runs clear (no bubbles) and is new.  ATE Dot4
I can only think that there is air trapped in the rear calipers - can they be bled upside down  ??? or any other way ?
Full Leather
= 99 Bora V5 =
golfvr6
« Reply #3 on: 25 November 2003, 13:47 »
Try the trick i suggested.
Offline Gambit
« Reply #4 on: 25 November 2003, 14:12 »
this may sound stupid, but you havent put them on back to front (upside down) have you? ie the right caliper rear on the left rear & vice versa?
the nipple is situated at the top when they are fitted yeah?
golfvr6
« Reply #5 on: 25 November 2003, 14:22 »
I don't think they would fit!
Offline AL16v
« Reply #6 on: 25 November 2003, 19:29 »
Gambit - Calipers are the right way up (bleed nipple at the top).
I'll try the suggestions at the weekend.  The brakes work, it's just the pedal feel that doesn't inspire confidence.
Al.
Full Leather
= 99 Bora V5 =
golfvr6
« Reply #7 on: 25 November 2003, 20:05 »
Are you using a pressure bleeder?
Offline mk1
« Reply #8 on: 25 November 2003, 20:27 »
Clamp each flexi one at a time, check the brake pedal to see if improves. If it does, then that is were the air is, if no improvement, then the air is in the pipework or the m/cylinder. Had a golf once that I could not get a good pedal on, unbolted the rear calipers and put a old pad between the pads to stop the piston poping out, rolled the caliper around to let any air caught in the back of the piston come out into the caliper body. Then held the caliper so the bleeder was right at the top and hey presto, a good dose of air poped out. Re-fit and all was well, good luck.
Steve.
Offline AL16v
« Reply #9 on: 25 November 2003, 22:20 »
Thanks guys, looks like I'll be busy at the weekend.  ::)
Full Leather
= 99 Bora V5 =
