Author Topic: Driver 1.6 MORE power?  (Read 5314 times)
Veedubgt18v
Re: Driver 1.6 MORE power?
« Reply #20 on: 22 March 2006, 09:04 »
yeah i put loads of work into mine and it worked fine for the summer and was sh!te in the winter then sorted that then it was a bag of nails in the summer then i got enough money and got a gti and now its a bag of nails all round lol (not really but i dont miss having to fiddle on a cold morning with my flaps......
oh err.....
Offline TanK_VW
« Reply #21 on: 24 March 2006, 14:35 »
how much is a weber?
Offline Si
« Reply #22 on: 24 March 2006, 14:39 »
Look on Egay. Prob pick one up for £50 i wouldv thought.?  :undecided:
While your on there, see how much you can get twin 40's for.... you might be suprised!  :nerd:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline TanK_VW
« Reply #23 on: 24 March 2006, 14:43 »
what difference does the twin port one do?
Offline Si
« Reply #24 on: 24 March 2006, 14:45 »
Twin Port Carb???  :huh:
You mean Twin Choke?
Offline TanK_VW
« Reply #25 on: 24 March 2006, 14:47 »
Can you tell i dont know what i am about when it comes to the engine lol.
Ok you tell me, whats the one u suggested?
and also what the difference between a twin port carb?
Offline Si
« Reply #26 on: 24 March 2006, 15:00 »
The Pierburg 2E2 Carb fitted to a standard 1.6 and 1.8 Driver is a twin progressive Choke.
Easiest way to describe how this works is you have 3 jets (i think).... :undecided:
also it has 2 Venturis... (flaps) 1st is open when driving normally to allow limited fuel / air mixture.
2nd flap opens (2nd Choke) when you accelerate harder to allow loads more fuel / air in to engine.
The Pierburg has more moving parts and several Jets (which block up)
Whereas the Weber only has 1 single jet i think so less moving parts.
Id seriously recomend sticking with the 2E2. When its setup and running correctly it is better than the Weber in my views.
To get real performance from a Carb Car your better off fitting Twin 40 Webers. These are two carbs mounted side by side to each other, but expect seriously poor MPG and they need to set up spot on or its bye bye pistons!  :cry:
Offline TanK_VW
« Reply #27 on: 24 March 2006, 15:05 »
how do you get it running smooth then?
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
« Reply #28 on: 24 March 2006, 15:53 »
2E2 Pierburg Repair thread - http://www.golfgtiforum.co.uk/index.php?topic=33259.0
Yes, got it in before Rubjonny  :grin:
Offline TanK_VW
« Reply #29 on: 24 March 2006, 15:59 »
Jesus that man knows everything!
