Author Topic: Squeaky clutch pedal  (Read 1025 times)
Offline mpgscott
« on: 18 March 2006, 20:04 »
Hi,
I have had a search and have not found anything.
When i press the clutch pedal on my 1992 k reg gti 8v the pedal is very sqeaky is this the cable or does it need a spray of oil?  The clutch does feel ok any thoughts.
Also car is quite spluttery and has just had a K+N induction kit fitted could this cause the poor running?  Should i re-fit the old air box?
Thanks
1996 VR6 Highline
2007 Aprillia Tuono
Offline msond
Re: Squeaky clutch pedal
« Reply #1 on: 20 March 2006, 14:35 »
I also had a similar problem with the clutch pedal (squeky and stiff). I changed the cable and this solved the problem.
I also encountered problems after installing a K&N induction kit - the engine started stalling when the clutch pedal was depressed. After removing the induction kit the engine ran fine.
Current - Mk 7.5 GTD with sunroof, keyless, Dynaudio, Pronav, , reverse camera, Art Velours trim and self park.
Previous -
Mk 7 GTD. Tornado red with Santiago wheels, Pro sat nav, keyless and winter pack.
Mk 6 Golf GT. Reflex silver, heated black leather, 18" Vancouver wheels, climate control, RCD 510 with DAB, Bluetooth, parking sensors, luxury & storage packs.
Mk 3 Golf GTi 8v Anniversary
Mk 2 16V
