Author Topic: Problems turning engine off  (Read 1997 times)
Offline T_J_G
Re: Problems turning engine off
« Reply #10 on: 06 April 2006, 12:55 »
Right i did the carb cleaner, no better.
Changed the coolant o ring and then the inlet manifold and it hasn't solved the problem.
what do i do now?
 :huh:
« Reply #11 on: 06 April 2006, 14:29 »
Replace the idle/overrun valve :)
Offline T_J_G
« Reply #12 on: 06 April 2006, 14:53 »
more stuff to replace...
is this known on GSF as IDLE CONTROL VALVE?
I really hope not as i don't have over 100 pound..
 :laugh: :sad:
modify:and they dont do one for my car.
« Reply #13 on: 06 April 2006, 14:57 »
I think the gsf one is for the GTI 8v & 16v, the carb one is small & square and is bolted to the back of the 3/4 point unit.
Offline T_J_G
« Reply #14 on: 06 April 2006, 15:02 »
do you know of part numbers for anywhere online for this bit?
How much should i be looking at for one?
Offline T_J_G
« Reply #15 on: 06 April 2006, 17:46 »
anyone? :laugh:
« Reply #16 on: 06 April 2006, 18:00 »
dont think there is anywhere you can buy em, perhaps ecp?  I'd just get a couple from a scrappy and test em, they should pass vacuum when off and not when on.  Or was it the other way round?
Either way, connect a vac hose and suck on it with & without a 12v supply to the electrical connection, should be obvious if its working or not ;)
Offline T_J_G
« Reply #17 on: 07 April 2006, 09:18 »
I haven't got a clue what you're talking aout or what i'm after!
« Reply #18 on: 07 April 2006, 11:33 »
See here:
http://www.golfgtiforum.co.uk/index.php?topic=33259.0
The part labled 'idling overrun control valve' is what I'm on about.  It has 2 vacuum hose connections on it, put a hose on one of them and try to suck air through it, with and without a 12v supply (e.g, plug it in and switch the ignition on/off)  If theres no difference between ignition on and off, then its knackered or it isn't getting a 12v feed from the ignition.  It should click when you turn the key :)
