Author Topic: intermitant heat  (Read 2203 times)
Offline pal1
intermitant heat
« on: 23 November 2003, 19:45 »
heaters work fine (nice and hot) until the engine temp hits 90degrees then they go warm i am thinking its a thermostat problem has anyone had a similar prob and how did they fix it  ???
Offline pal1
Re:intermitant heat
« Reply #1 on: 23 November 2003, 21:19 »
has no one got any ideas
Veedubgt18v
Re:intermitant heat
« Reply #2 on: 23 November 2003, 21:21 »
I havent had this but leave the post time for more people to read it and they might know  :)
Offline m4nesh
Re:intermitant heat
« Reply #3 on: 24 November 2003, 08:45 »
its unlikely to be your thermostat because your car is heating up fine, but does your car maintain a constant temp on the temp gauge, if so then you can rule out the thermostat..
One thing everyone here at this forum will advise you is that if having a problem with your heating change the "BY-PASS VALVE".... its only 28 squid inc VAT.....before you take my advice see what the gti geeks say
Offline pal1
Re:intermitant heat
« Reply #4 on: 24 November 2003, 14:30 »
i think ive sorted it ive by passed the by pass valve and it works fine for now i will have to order one from vw ;)
